Canberra Oil Train II - Triple X's (And Garbo with DL lead)
Started by Sir Pompously, December 18, 2009, 04:13:27 PM
Went chasing the Canberra Oil Train and the Crisps Creek garbage train. Yesterdays oil was quite different from normal, it had 3 X's, and a trial was performed with X47 leading X52 and 50 out to Bungendore and return before perfomring their usual shunt and offload into shell. X47 was the only one online, so it is presumed they were performing a load test.
Oil Train
The Canberra Fuel Train is seen back tracking to shunt into towards its siding. Only two of three X's performed this shunt
X47 leads X52 and 50 into Bungendore, passing one of the few Semaphore signals left on the line on a Canberra Fuel service
A Canberra Xplorer service is passing the Canberra Fuel service in Fyshwick. A note that the centre carriage is still in the original scheme, a scene soon to disappear. Also the Xplorer service rarely passes the Fuel train here
Triple X Class depart Tarago NSW
Oil Train departing Tarago. Click link to watch in HD
Test Run to Bungendore
X47 leads X52 and X50 on a test train to Bungendore, and is seen passing the Kings Hwy near Burbong. X47 was the only unit working at this point, and the screaming it made coming up the gorge was unforgettable
X47 is seen leading X52 and X50 on a test train to Bungendore, taken at Hoskinstown Road level crossing near Bungendore Junction
Garbage Train
DL50 leads 8004 and 8105 on the Garbage Train, departing Crisps Creek and entering Tarago
DL50, 8004, 8105 pass through Joppa Junction, onto the Main South Line from the Bombala Branch (Canberra line)
