Photos Of Bus 353
Started by Bus 400, August 02, 2009, 09:10:27 PM
[font='ms shell dlg']I decided to go for a few different angles, the right side headlight is brighter because of a crack in the headlight glass.[/font][font='ms shell dlg'][/font][font='ms shell dlg'][/font][font='ms shell dlg'][/font][font='ms shell dlg'][/font][font='ms shell dlg']This one is a stuff up that looks weird[/font][font='ms shell dlg'][/font]
First one is nice.
Third one would've been a nice angle under better lighting conditions.
Just a tip, when you are taking pics at night get the driver to turn the high beams off!
The high beam was off, apparently the right low beam glass bit was cracked, so the light was brighter put of it.
Ed
QuoteJust a tip, when you are taking pics at night get the driver to turn the high beams off!
It doesn't look like the high beams are even turned on in those night shots. I reckon the photos would have been better if you got the driver to turn the headlights off altogether.
Try using the lights on Parkers, or off. As the light itself distorts a fair bit of the image. Also the last one, it is not weird, it is quite normal and is just what happens when you move the camera up and down infront of light. Done right it can look ok, however that is in art and not really for transport photography. Oh and I am exasperated at you for using 'An Evening with....', please make up your own titles instead of stealing the song idea John had and my own :P
