November 12, 2019, 10:17:57 am
Bus Stop Modifications
Started by Bus 400, August 22, 2010, 07:17:45 pm
Checking the contract register: found a new contract for "Upgrade of Bus Stops 2596 & 2598 Kingston [Shops] and Minor Works at Stop 4567". (4567 is Northbourne Av near Morphett St)
Under the new network many bus stations have been renamed or existing names adjusted. Comparing the names from old and new bus books:-
City Bus Station became City Interchange;
Belconnen Community Bus Station became Belconnen Interchange;
Westfield (Belconnen) Bus Station became Westfield Belconnen;
Cohen St (Belconnen) Bus Station became Cohen St Interchange;
Woden Bus Station became Woden Interchange;
Tuggeranong Bus Station became Tuggeranong Interchange;
Gungahlin Town  Centre became Gungahlin Place;
Continuing unchanged is Dickson Interchange.
Interesting, as has been mentioned, there are inconsistencies in the application of 'Interchange' in the naming. Notably at Gungahlin where, though the name applies to both bus and light rail, 'Interchange' is omitted; two interchanges at Belconnen; and the City light rail terminus not indicated as an 'Interchange'.
(A recent post used an old name, so I thought it might be useful to list all the names in one place.)
Quote from: triumph on May 02, 2019, 10:17:09 pmUnder the new network many bus stations have been renamed or existing names adjusted. Comparing the names from old and new bus books:-
And Barton remains a "Bus Station."
Quote from: King of Buses on May 02, 2019, 10:30:24 pmAnd Barton remains a "Bus Station."
I had confined my post to the locations diagrammed in the Time Table books.
It is more than Barton, there other 'bus stations' and 'interchanges' including (not a comprehensive search):
- Eastern Valley Way Bus Station;
- Kippax Interchange;
- Cooleman Court Interchange;
- Erindale Interchange.
There are inconsistencies between on-line indexing, on-line detail, printable on-line version, and the books. Erindale is either a centre or interchange depending where you look; Eastern Valley Way Bus Station seems only to appear as an outbound departure point for some  Belconnen local services (eg 42) in the on-line detail with Belconnen Interchange being the outbound departure point in other sources. Emu Bank Bus Station seems to have disappeared.
Well the on-board announcement still says Emu Bank Bus Station.
Quote from: Sylvan Loves Buses on May 04, 2019, 11:41:29 pmWell the on-board announcement still says Emu Bank Bus Station.
Yet another source of inconsistencies.
Transport Canberra in its major overhaul of the network (and the 3 month postponement of the new network) had a golden opportunity to fix up inconsistencies and some longstanding problems (like the panels sometimes not showing the current service approaching, indicating incorrect platforms, etc) but appear to have muffed it.
At the end of the day the naming of a location as an interchange, bus station etc. is meaningless to the general public who won't look past the first word/name of the place, unless they're asking/telling someone where they're going and confirming such as, "dose this bus go to the city"...."where in the city"...."the interchange"...."yes" I do agree it is annoying and should be consistent, whilst I was never for the change to bus station, they should have made all the bus ONLY stations 'Bus Stations' and should've made City and Gungahlin Interchanges and called the Light Rail Stops the same name, such as they have correctly done at Dickson.
This seems to be the only reference, but I verified it today by travelling to it on a terminating service and the driver confirmed it is still a valid destination.
From today, Stop #5520 (Eastern Valley Way "Bus Station") has been moved to before Cameron Avenue due to building works.
This means that all services which commenced from there will now do so from Platform 5 of Belconnen Interchange (aka Belconnen Community Bus Stn).
Oh so the timetables are actually accurate now huh?
Quote from: Barry Drive on June 05, 2019, 11:59:19 amFrom today, Stop #5520 (Eastern Valley Way "Bus Station") has been moved to before Cameron Avenue due to building works.
At this stop Monday morning. Several signs had been posted but were incorrectly worded. The wording suited posting at the temporary stop not at the stop being temporarily closed.
Effectively, the signs told the public that the stop replaced stop 5520 (ie the stop replaced itself) and advised about commencing services departing from the Belconnen Interchange. There was no guidance to the temporary stop, so the impression likely to be received would be that work was being done at the stop, so some services had been moved to the Interchange; or,  if the stop number was not noticed on the blade, that the stop was standing in for another stop elsewhere.
Today, on an R3 I noticed a person was allowed to board and was 'chipped' by the driver to use the temporary stop next time. If the signs are still the same (which I haven't had an opportunity to check) then it is valid, based on the advice in the signs, to expect R and other passing services to stop.
