Tuggeranong Valley Services
Started by Bus 400, September 30, 2009, 07:56:42 PM
These are changes which I believe could simplify some routes & maximize on areas not covered.
60-62 stay the same.
63 Woden Interchange via Monash & Waniassa
  • S Tuggeranong Interchange
  • C Pitman Street
  • L Athllon Drive
  • L Soward Way
  • R Anketel Street
  • L Athllon Drive
  • C Isabella Drive
  • L Clive Steele Avenue
  • L Corlette Crescent
  • R Hebble White Street
  • R Harricks Street
  • L McBryde Crescent
  • R Mackinnon Street
  • L Sternberg Crescent
  • R Wheeler Crescent
  • L Garratt Street
  • L Langdon Avenue
  • R Athllon Drive
  • L Parramatta Street
  • R Townsend Street
  • R Botany Street
  • R Hindmarsh Drive
  • L Callam Street
  • F Woden Interchange
64 Woden Interchange via Monash & Wanniassa
  • C Pitman Street
  • L Athllon Drive
  • L Soward Way
  • C Erindale Drive
  • R Charleston Street
  • L Sturdee Crescent
  • R Harricks Crescent
  • R Sternberg Crescent
  • L Wheeler Crescent
  • R Kirkton Street
  • L Langdon Avenue
  • R Gaunson Street
  • L Longmore Crescent
  • R Sainsbury Street
  • R Langdon Avenue
  • R Athllon Drive
  • C Callam Street
65 Woden Interchange via Isabella Plains, Chisholm, Gowrie & Wanniassa
  • Only change is that Route 65 now goes the full length of Longmore Crescent
66 Woden Interchange via Bonython, Gowrie & Fadden
  • C Pitman Street
  • L Athllon Drive
  • L Soward Way
  • R Scollay Street
  • L Athllon Drive
  • R Barr Smith Avenue
  • R Hurtle Avenue
  • L Drakeford Drive
  • R Isabella Drive
  • L Ashley Drive
  • R Bugden Avenue
  • C Sternberg Crescent
  • R Langdon Avenue
  • R Athllon Drive
  • C Callam Street
I believe this run would get rid of one of the most hated intersections in Canberra (trying to turn right from Bugden Avenue onto Ashley Drive in peak time.
67 Woden Interchange via Calwell, Richardson, Gilmore, Monash & Erindale
  • NORMAL RUNNING TO CHISHOLM SHOPS
  • C Benham Street
  • L Isabella Drive
  • R Cockcroft Avenue
  • L Baraclough Crescent
  • R Clive Steele Avenue
  • L Ashley Drive
  • R Comrie Street
  • L Erindale Drive
  • L Sulwood Drive
  • R Athllon Drive
  • C Callam Street
68 Woden Interchange via Richardson, Chisholm & Gowrie
  • C Pitman Street
  • L Athllon Drive
  • L Soward Way
  • R Scollay Street
  • L Athllon Drive
  • R Drakeford Drive
  • L Johnson Drive
  • L Clift Crescent
  • R Heagney Crescent
  • L Baskerville Street
  • R Hambridge Crescent
  • L Halley Street
  • L Benham Street
  • R Isabella Drive
  • L Coyne Street
  • R Carson Street
  • L Jackie Howe Crescent
  • R Coyne Street
  • L Bugden Avenue
  • R Casleton Crescent (1st one)
  • R Erindale Drive
  • L Sulwood Drive
  • R Athllon Drive
  • C Callam StreetF Woden Interchange
*With all these services using Athllon Drive through the Woden Valley the Intertown service would run non stop through Woden Valley.
bubzie
ahhhh, i believe in mornings, turning right from budgen into ashley is no problem....for the love of god, you have right of way!!!
(ok, cant comment on evenings yet..)
    Quote from: Bus 400 on September 30, 2009, 07:56:42 PM
    [/list]*With all these services using Athllon Drive through the Woden Valley the Intertown service would run non stop through Woden Valley.
    You would need to atleast stop the intertown at Mawson, as there are two Schools and a Park and Ride facility in place.
    There is so much wrong with this, I don't know where to start. When will you get over your obsession with a route along Jackie Howe Cr - it's NEVER GOING TO HAPPEN. And I doubt that Sturdee Cr is particularly bus friendly either.
    I'm not sure how Wanniassa and Monash will like having their route to Erindale removed (not sure whether Erindale would be too happy either).
    The best way to simplify these services would be to consolidate Wanniassa into two routes (rather than four) and to run most routes through Erindale.
    Sturdee Crescent actually does have bus stops along it though.
    Quote from: bubzie on October 01, 2009, 06:11:25 AM
    You don't have the right of way if you are turning out of Bugden into Ashley. Turning left OR right out of there in peak periods can really test your patience, even more so when you've got a 12m+ vehicle to negotiate out of there..
    Remember, cars may be able to make use of the teeny little 'waiting lane' when turning right, but the buses can't.
    bubzie
    whoops...i was thinking the other side... :S
